Outside Light With PIR Installation not Turning off?
Jeff5143
by Jeff5143 » Thu May 14, 2020 1:25 pm
I installed the light outside my attached garage on a brick pier next to my house wall which is running 9 inches away along side the brick pier but trying all adjustments it will only come on when it is dark but never turns off after a while. I have tried all settings but without success, so I am now wondering if the static brick wall is being detected and so stopping it turning off?
As the brick wall is motionless obviously can it effect the sensor on my light.
Any help or information would be helpful thanks.
Re: Outside Light With PIR Installation not Turning off?
by stoneyboy » Fri May 15, 2020 10:26 pm
Hi Jeff5143
Is there a setting on the pir for dusk to dawn operation?
Jeff5143
by Jeff5143 » Sat May 16, 2020 1:09 pm
Thanks for your answers but I have not explained it well enough.
The light can be adjusted to come on when dark and off in daylight but will come on again in the daylight and stay on, so I was wondering if the brick wall close to the side of it is being detected which I thought was making it come on again in daylight. It was either that or it was faulty.
by stoneyboy » Sat May 16, 2020 11:14 pm
Hi jeff5143,
Assuming that it is not installed in a dark corner (with an overhang above it) and you have an infrared pir rather than a microwave one it is likely that the unit is faulty.
Jeff5143
by Jeff5143 » Sun May 17, 2020 9:58 am
Thanks I agree so I sent it back to the suppliers. TX
It is currently Sat Jan 11, 2025 6:22 am
