Re-Apply Bitumen paint over previously applied Bitumen paint
intarsia
by intarsia » Thu Jun 04, 2020 1:37 pm
Hello -
A couple of years ago I undertook repair to a large felt roof at my house as it was cracking in places but not leaking. I applied two coats of Bitumen primer and then one coat of Bitumen paint with a second coat on joins and high water areas such as under the guttering etc. I used an entire 25 litres of the bitumen paint which gives you an idea of the roof space.
As the weather has improved I wanted to re-apply the bitumen paint to keep it performing well.
Questions:
Is it possible to re-apply bitumen paint over older bitumen paint?
Would I need to re-apply the primer or anything?
Thank you in advance for your support.
Re: Re-Apply Bitumen paint over previously applied Bitumen paint
by stoneyboy » Thu Jun 04, 2020 10:30 pm
Hi intarsia,
If your bitumen paint is solvent based you will probably be ok with a clean with a stiff brush only. If it is waterbased you will probably need to use a primer.
Have a look at the instructions on the tin.
intarsia
by intarsia » Sun Jun 14, 2020 10:44 am
Hello -
Thank you for the response, I've checked with the manufacturer and they've confirmed it's solvent-based. I will take your advice and re-apply in parts where required. Thankfully there's minimal moss build-up and I've maintained the roof periodically by gently brushing it clean.
Hopefully this will continue to prolong the life of the roof.
Thank you.
It is currently Tue Jan 07, 2025 2:31 am
