flooring
6 posts   •   Page 1 of 1
palpal
flooring
by palpal » Sun Mar 25, 2007 11:10 am
I have a kitchen /diner the kitchen floor is screeded and the diner is floorboards the kitchen floor is higher by a few mm where it joins the timber floor what is the best way to raise the level of the diner floor?the floor when completed will be covered with sheet vinyl many thanks jp
thedoctor
by thedoctor » Sun Mar 25, 2007 6:04 pm
How arew the floorboards fixed or is it a floating floor, or even laminate.
palpal
by palpal » Sun Mar 25, 2007 6:13 pm
[quote="thedoctor"]How arew the floorboards fixed or is it a floating floor, or even laminate.[/quote]
thanks for the reply as far as i know the boards are nailed to joists on a suspended floor
palpal
by palpal » Sun Mar 25, 2007 6:18 pm
thanks for the reply the boards are nailed to suspended joists
mack4
Floor levels
by mack4 » Sun Mar 25, 2007 6:36 pm
Are you going to cover both kitchen and diner with the same material?Bear in mind there will be movement between screed and boards, which may lead to the vinyl failing,at that point ,in the future.The joint should be overlapped from the boards onto the screed by at least 150mm and fixed by screws or construction adhesive.The resulting edge in the kitchen can then be smoothed off by self-levelling latex screed.
palpal
by palpal » Mon Mar 26, 2007 10:50 am
Cheers for the info
It is currently Fri Nov 22, 2024 3:51 pm
