What to use to stick a ceiling tile?
Mysteryman
by Mysteryman » Sun Jun 21, 2020 12:09 pm
I need to replace a single ceramic ceiling tile and am not sure what the best adhesive is to use. Also, because it is just one tile I would rather not have to buy a massive quantity!
The tile is 240mm x 335mm and about 10mm thick, so, there is a bit of weight in it and I need to be sure it is not going to drop off!!!!
I have attached a photo, which shows that it will be stuck on to wood (looks like ply-board)
Any suggestions on what to use?
Re: What to use to stick a ceiling tile?
by stoneyboy » Mon Jun 22, 2020 10:23 pm
Hi mysteryman
Suggest you use solvent based gripfil or something similar. If this really is a tile fitted to the ceiling I would recommend a mechanical fixing be added.
It is currently Sun Nov 24, 2024 1:52 am
