Do I need to insulate garage floor?
7 posts   •   Page 1 of 1
thewallsare
by thewallsare » Sat Jun 27, 2020 10:45 am
Garage conversion into an office space separate from the house.
Do I need to insulate the floor with the really thick boards? Currently, it is just concrete.
I don't want to raise the floor much due to the height of some props I need to keep in the garage.
I am thinking to either painting the concrete floor directly with some good paint or putting underlay and laminate on it which I suppose would be better for warmth.
Ta
Re: Do I need to insulate garage floor?
by stoneyboy » Sat Jun 27, 2020 11:53 pm
Hi thewallsare
Your laminate floor will be the best option but use an underlay which form a DPM.
RegardsS
Hi thewallsare
RegardsS
thewallsare
by thewallsare » Sun Jun 28, 2020 12:37 pm
stoneyboy wrote:Hi thewallsare
RegardsS
Thanks. Can you get laminate underlay which has DPM in them? Or would I need to lay DPM layer then put laminate underlay on top?
by stoneyboy » Mon Jun 29, 2020 10:32 pm
Hi thewallsare
You can buy underlay which forms a DPM the joins are double lapped with continuous adhesive.
thewallsare
by thewallsare » Mon Jun 29, 2020 10:42 pm
Thanks, can you name a product? Finding it hard in my searches to see any :/
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
by B4Less » Thu Dec 03, 2020 3:54 pm
Unfortunately your office will get very cold in the winter if you do not insulate the floor. Maybe look at using a good Multifoil insulation on top of the concrete and then an really good underlay and timber floor or carpet if you are stuck for space. If you can I would suggest you use Kingspan Kooltherm if you have the space.
It is currently Sun Nov 24, 2024 2:08 am
