Disconnecting a gas hob temporarily
ZoolPool
by ZoolPool » Sat Jun 27, 2020 7:38 pm
Hopefully an easy one. I need a gas hob disconnecting temporarily.
Can I just turn this valve and remove the pipe that goes to the hob? Then reconnect it in a few days?
Thanks all!
Re: Disconnecting a gas hob temporarily
by stoneyboy » Sun Jun 28, 2020 9:48 pm
Hi zoolpool
Yes you can isolate you hob using the valve but mods to the pipe work should be carried out by gas safe engineer.
It is currently Sun Dec 22, 2024 8:03 am
