Outside Light Wiring with no PIR Required
Smithy85
by Smithy85 » Sun Jun 28, 2020 5:49 pm
Hi All,
I’ve bought an outside light but not PIR so no permanent live required.
Could you help with identifying wire for neutral and live on my new light?
I have taken photos of internal switch first photo and wires outside as well to help.
Is the black covered in brown switched live but which is neutral on external and permanent live?
Thanks in advance
External wires, no PIR on new fitting
Internal switch rear
Re: Outside Light Wiring with no PIR Required
by Mr White » Sun Jun 28, 2020 11:30 pm
Without testing it is not possible to give a definitive answer, but my guess would be the one sleeved blue is the neutral and the one that is actually brown is the permanent live.
Smithy85
by Smithy85 » Mon Jun 29, 2020 9:25 am
Thanks, I’ll test to confirm. Given I do not need the permanent live for this light, it is terminated in a ‘Choc block’ and covered in tape?
by ericmark » Mon Jun 29, 2020 4:25 pm
Looking at picture of switch, brown is always line, so not required, black with brown sleeve is switched line, and grey with blue sleeve is neutral.
It is currently Sat Jan 11, 2025 3:06 am
