Float on toilet cistern fill pipe stuck
DarrenNI
by DarrenNI » Sun Jul 19, 2020 10:55 am
Hi folks,
The float on our toilet cistern waste pipe appears to be stuck - it doesn't go down when the cistern empties, and doesn't rise when it fills. (Or it may be that the arm that connects it to the valve is stiff)
There's (hopefully) a video of it here: https://photos.app.goo.gl/N82qZ9BVxAN3wyjJ8
Is there a way to fix this, or will I need to fit a new fill valve?
Thanks!
Re: Float on toilet cistern fill pipe stuck
by stoneyboy » Mon Jul 20, 2020 9:24 pm
hi darrenni
Unless the float adjustment screw has been adjusted too far you are probably best fitting new.
It is currently Tue Dec 03, 2024 8:44 pm
