No cold water from bathroom taps only a trickle
NickP
by NickP » Sat Jul 25, 2020 1:50 pm
In my bathroom, when I switch on any of the cold taps I get an extremely small trickle of water out of them. The sink tap is a mixer tap and the bath taps are individual taps. The thermostatic shower also will only run hot water. The cold water in the en-suite which is next to it (and all other taps in the house) run fine. I have noticed that if I switch on the cold tap and then switch on the shower to hot, the water will start flowing out of the cold taps however it will be hot water. Does anyone have any ideas as to what maybe causing this?
Many thanks in advance
Nick
Re: No cold water from bathroom taps only a trickle
by stoneyboy » Sat Jul 25, 2020 11:24 pm
Hi nickp
You've probably got an air lock in the cold pipework. Try using a mains hose to blow into the open taps that don't work.
NickP
by NickP » Sat Jul 25, 2020 11:36 pm
Hi stoneyboy,
Thanks very much for your reply.
Many thanks
Nick
MrBen
by MrBen » Sun Jan 24, 2021 3:20 pm
Hi Nick,
Did you get this fixed - I have exactly the same issue and it's not an airlock unfortunately.
Ben
It is currently Mon Dec 02, 2024 8:52 pm
