Random cable behind brick fire surround
ajaw
by ajaw » Sun Jul 26, 2020 2:26 pm
Behind a decorative, 80's style brick fire surround, I found a cable and exposed wires. I have tracked it upstairs and under the floorboards. It is wired into a round junction box, which has one cable in and one out (the one going downstairs).
Is it safe to disconnect the cable from downstairs and then seal the junction box back up? Will the junction box be safe?
I intend cutting off the cable downstairs so it can be buried under fresh plaster.
Thanks, ajaw
Re: Random cable behind brick fire surround
by stoneyboy » Sun Jul 26, 2020 10:43 pm
Hi ajaw
There should not be a problem doing this but turn off the electric. It would be wise to use some sort of tester to make sure both ends of the cable are dead when you turn back on.
ajaw
by ajaw » Mon Jul 27, 2020 10:27 am
Thank you for your reply.
It is currently Sat Jan 11, 2025 2:57 am
