Does a sanded down internal door need priming?
Zacccc
by Zacccc » Thu Jul 30, 2020 1:53 am
I've sanded down an internal door and in a few places it's gone down to the bare wood. Do I need to prime these patches of bare wood before painting the door or can I just put on two or three coats of the water-based Dulux QuickDry Satinwood pure brilliant white which I'm using, and which the tin says is self-undercoating?
If I do need to prime the bare wood bits is it better to use a water-based primer or a solvent-based one?
Thanks.
Re: Does a sanded down internal door need priming?
by stoneyboy » Thu Jul 30, 2020 2:34 pm
Hi zacccc
Suggest you use a water based primer/undercoat for compatibility, this will raise the grain slightly so you will need to sand between coats.
Zacccc
by Zacccc » Thu Jul 30, 2020 5:32 pm
I already have a solvent based primer and I've been told that that's ok to prime with (which would save me buying another primer), but thank you for your reply.
It is currently Thu Nov 21, 2024 11:34 pm
