Does our chimney need rendering?
StevieDC
by StevieDC » Fri Aug 07, 2020 10:56 am
It looks likely that our chimney requires re-rendering.
Could someone confirm that for me?
It straddles the two houses (semi-detached) so, I presume, my neighbour will pay half the costs (?)
Is is possible to only re-render my half if they refuse?
thanks,
Steve.
Re: Does our chimney need rendering?
by stoneyboy » Fri Aug 07, 2020 11:03 pm
Hi steviedc
Unless you are getting water ingress suggest you ignore it.
StevieDC
by StevieDC » Mon Aug 10, 2020 10:58 am
Thanks Stoneboy.
There doesn't appear to be any water getting in.
I'd certainly like to ignore it but, as it is our house and we will probably be here for years, I'm inclined to get it done sooner rather than later. Before it gets worse and does cause water damage.
Cheers.
StevieDC
by StevieDC » Mon Apr 19, 2021 10:47 am
It appears to be getting worse quickly.
Could someone give me an idea of how much this should cost to get fixed? Thanks.
It is currently Sun Nov 24, 2024 1:46 am
