What tool is used to unscrew this
May148706
by May148706 » Fri Aug 14, 2020 4:55 pm
I've tried a large flat blade and Allen Key and it didn't work! Thanks
Re: What tool is used to unscrew this
by stoneyboy » Sat Aug 15, 2020 9:41 pm
Hi may148706,
You need to use a screwdriver large enough to locate in both slots at the same time. If is will not shift you may have to use a punch for the initial release.
May148706
by May148706 » Sun Aug 16, 2020 12:40 pm
Thanks a lot ... I thought it needed a special tool!
I can't seem to find a screwdriver with a head larger than 12mm and a small size handle. Any suggestions where to look for these?
by stoneyboy » Sun Aug 16, 2020 10:24 pm
Hi may148706
See if you can find a piece of flat steel the right width and use this with an adjustable spanner or grips.
by stoneyboy » Sun Aug 16, 2020 10:25 pm
Hi may148706
See if you can find a piece of flat steel the right width and use this with an adjustable spanner or grips. A coin might do the trick.
It is currently Thu Dec 05, 2024 2:11 am
