Double glazing filtration is this is supposed to be normal?
6 posts   •   Page 1 of 1
nish_b
by nish_b » Tue Aug 18, 2020 8:22 am
Good Morning Folks
I would appreciate some guidance please. I had some new windows fitted over 2 years ago - they are triple glazed. I have noticed some 'gunk' come out or the area just above where the handle is. It cleans away with a strong cleaner and elbow grease. However I never had these on my older windows. I have been advised this is due to the great filtration system my windows have - so great it makes my windows look grubby and this happens when its rains. They came and took out two chunks from all the windows frames to help the water filter through. I just need some additional guidance as to what is going on here. All help appreciated.
This shows where they took a bit out of the frame to help water through
This is what happens regularly.
Re: Double glazing filtration is this is supposed to be normal?
by stoneyboy » Wed Aug 19, 2020 6:33 pm
Hi nish_b
Are you referring to the dirt in the frame channel or the dirt in the edge of the glazing bead.
nish_b
by nish_b » Wed Aug 19, 2020 7:06 pm
Hi Stoney Boy - the dirt in the bead.
Nish
by stoneyboy » Thu Aug 20, 2020 2:45 pm
Hi nish_b
In that case the most likely cause is that there are problems with the external sealing to the glazing units.
Have a look at the outside and see if there are gaps in the external rubber bead - poorly joined corners are the most likely issue.
nish_b
by nish_b » Fri Aug 21, 2020 12:41 am
The guy that has done it reckons this is normal
by stoneyboy » Fri Aug 21, 2020 9:54 pm
Hi nish_b
The rebate that the TGU's are fitted in should be totally sealed to outside rain. Your original post indicates that the problem occurs when it rains so rainwater must be getting between the TGU and the frame rubber seals. The rubber seal should be a tight fit against the TGU so try pushing the TGU inwards and see if you get a gap.
It is currently Mon Jan 06, 2025 9:03 pm
