hi there, i have a double socket (2 plug outlets) in my kitchen that's not working. all the other ones in the kitchen (one double and one single) and elsewhere in the flat work fine. i've checked the fuse box unit and all the mcb's are up (on). there are 2 red ones which are 32 amps so i think these are the ones controlling the socket outlet circuits. anyway, like i say they're all up so i presume none have tripped. as far as i can remember this socket has never worked but it would be really useful because at the moment we are having to run an extension cable from the nearby single socket to plug in the cooker (which is gas but also has a plug for its electric functions - lights, timer, clock, fan), and then another extention cable plugged into the first one to reach the fridge/freezer and washing machine. the kettle, microwave and toaster are all plugged into an exact same double socket on the other side of the kitchen. i've opened both double sockets and they both look like they're wired exactly the same and none of the connections are loose. do you think maybe the cable to this duff socket is damaged somewhere? there's no sign of it having been overloaded or anything as the white faceplate has no brown burn marks anywhere. i'm no electrician and don't wanna spend tons calling one over unless i have to so would appreciate any advice.
thanks in advance for any help
danjo
