Water tank only heating on override
photosynthesize
by photosynthesize » Wed Oct 21, 2020 11:11 am
Hello
I don't have central heating but I do have a hot water tank, which is set to heat up every day at noon. In the last week or so it hasn't been doing this, but if I use the temporary override it works fine.
The time of day is correct on the clock and the pins are present and in place. Any suggestions?
Thank you.
Re: Water tank only heating on override
by stoneyboy » Thu Oct 22, 2020 10:49 pm
Hi photosynthise
Sound like you have a 2 immersion tank and the main bottom immersion has failed. If this is the case replacement is your only option.
photosynthesize
by photosynthesize » Thu Oct 29, 2020 6:12 pm
Urgh. Nightmare. Does that mean replacing the entire tank?
by stoneyboy » Fri Oct 30, 2020 9:44 pm
Hi photosynthesize
No just the immersion heater.
It is currently Sun Nov 24, 2024 5:27 am
