Shower mixer cartridge removal advice required
c9mber
by c9mber » Fri Oct 23, 2020 10:03 pm
I would greatly appreciate advice in removing a mixer tap in my bathroom. I took it all to pieces the other day but spent so long trying to work out how to remove the mixer that I had to put it all back together again to have a wash/have a drink/wash hands! I assume all I need is a decent wrench to loose then top nut?
Here's a photo of what I'm working with - no YouTube tutorials were able to help me to unscrew/remove the mixer. Any ideas before I dismantle again and stop the shower from leaking?
Shower mixer stuck
Shower mixer stuck
Re: Shower mixer cartridge removal advice required
by stoneyboy » Sun Oct 25, 2020 9:47 pm
Hi c9mber
Presumably you took the valve apart exposing the cartridge which has a hex head for removal. If you have a replacement cartridge you have a chance of success but only if you can undo the old cartridge without messing up the hot and cold feed pipe work.
It is currently Mon Dec 23, 2024 2:51 pm
