Tiling in a shower after damaging tiles and plaster board
harveyW
by harveyW » Tue Nov 10, 2020 10:27 am
I have to fix a new shower door and when removing the old one managed to take some tiles and plaster board with it! This left a big hole in the shower. I made a wooden frame, secured it to the existing joists and attached new plasterboard to it. Now I need to tile over the plasterboard. Should I fill in the gaps at the sides and does anyone have any advice about tiling onto plasterboard. Thanks in advance.
Re: Tiling in a shower after damaging tiles and plaster board
by stoneyboy » Fri Nov 13, 2020 9:49 pm
Hi harveyw
You should be using tile backing board in this area and you must fit a complete framework around the hole so that there is no movement between the existing and new board.
It is currently Thu Nov 21, 2024 2:56 pm
