Fused Spur Timer for Existing Panel Radiator
DaiBach
by DaiBach » Thu Nov 26, 2020 5:53 pm
Panel radiator with Fused switch next to it.
The current switch has ENL connections, each with 2 wires feeding in. There is also a much narrower gauge grey wire connector.
My new timer switch has SUPPLY E & N and LOAD E & N, together with 2 earth's (6 connectors).
How do I know which live and which neutral go into which hole and what is the grey wire all about? I assume it doesn't matter which of my 2 earths go into which E hole?
I'll add images shortly as soon as I've reduced file size.
Re: Fused Spur Timer for Existing Panel Radiator
by ericmark » Sat Nov 28, 2020 6:32 am
Reading I wonder if this is an Economy 7 or similar set up? The grey wire may be a trigger wire to tell the heater when to switch on.
It is currently Fri Jan 10, 2025 11:12 pm
