Replacing old bath deck mounted taps (copper fittings)
rainandsnow
by rainandsnow » Sun Dec 20, 2020 2:10 pm
Hello,
I am unsure of this fitting type, is it a simple screw/unscreew with spanner or does it require a solder and I may need to get a plumber?
Thanks in advance.
Re: Replacing old bath deck mounted taps (copper fittings)
by stoneyboy » Mon Dec 21, 2020 11:55 pm
Hi rainandsnow
If there is a compression joint further down the pipe, undo this and you should then be able to remove the connecting pipe.
rainandsnow
by rainandsnow » Tue Dec 22, 2020 11:02 am
Hi stoneyboy,
Unfortunatly not, I can see the pipe is connected directly to another soldered joint.
I could cut it and replace it with somthing like this flex tap, push fit ?https://www.screwfix.com/search?search=jg+speedfit+flex+tap
by stoneyboy » Tue Dec 22, 2020 10:20 pm
Hi rainandsnow
That is the easiest solution just be careful to get the length right so that there are no kinks in the flexibles. Use a rotary pipe cutter so you get a neat end,and check you are not dealing with 3/4” pipe rather than 22mm.
It is currently Wed Nov 27, 2024 3:56 am
