Insulating under caravan - is membrane needed?
Perry123
by Perry123 » Wed Jan 06, 2021 6:53 pm
Looking for some guidance, I am going to insulate the underneath of my static caravan using fiberglass rolls and was planning to either use insulation support netting or a damp proof membrane sheet to keep the insulation in place.
I am just trying to find out which option would be best, the caravan is boarded round the bottom on all sides so no water can get to the underneath.
Will there be any issues using the netting as the insulation wouldn't be covered and open to the air under the caravan?
Thanks to any that can help :)
Re: Insulating under caravan - is membrane needed?
by stoneyboy » Thu Jan 07, 2021 4:08 pm
Hi perry123
Probably better to use netting so any condensation can evaporate.
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
by B4Less » Mon Jan 25, 2021 3:24 pm
If you want to use a wool type insulation, then use Rockwool. Its waterproof and insects hate it. Using a netting is a good idea to stop the insulation from falling, but mice etc. might like that so might be a good idea to use some timber laths also just in case. Rockwool RWA45 will do the trick for you.
Regards,
Build4less
It is currently Thu Nov 21, 2024 6:57 pm
