How do I fit flush pipe seal for Geberit low height cistern?
nigelpbwye
by nigelpbwye » Mon Feb 01, 2021 12:17 pm
Hi, need some help fitting a new seal and c-clip for Geberit cistern. I know where it needs to go but can´t see how to get the flush pipe off without dismantling the cistern, i.e. I can´t just pull the pipe out of the cone/pan because the mounted cistern doesn´t have any slack in it. Can anyone help or is it necessary to take the cistern off (see images)?
Thanks!!!
2021-02-01 12_14_08-2021-02-01 12_12_56-2021-02-01 12_11_05-Microsoft Office Picture Manager - Visua.png
Re: How do I fit flush pipe seal for Geberit low height cistern?
by stoneyboy » Tue Feb 02, 2021 10:26 pm
Hi nigelpbwye
Probably easiest to drain the cistern, undo the fixing bolts and lift upwards to give access to the flush pipe.
It is currently Mon Dec 23, 2024 10:20 am
