repair to plasterboard
rnd
by rnd » Tue Oct 02, 2007 9:55 am
hi all , can anybody advice me , iam a little confused , iam about to repair a hole in my plasterboard which will be about 1 foot square when ive cut it back and replaced with a new board . but before i go any further i was told to use bonding/ browning first then skim over ( when dry ) with finish .
but to add to my confusion someone else told me to just skim over with finish .
who is right ? or do both methods work .
kbrownie
by kbrownie » Tue Oct 02, 2007 9:48 pm
Hi rnd,
If the board is near level, should really be stepped back a little bit about 3mm or so, then just skim the board. Browning and bonding used for other apllications, normally straight on to brick and block work then you skim over!
Good Luck
KB
rnd
by rnd » Wed Oct 03, 2007 8:47 am
hi kbrownie, thank you so much,
It is currently Fri Nov 22, 2024 3:45 am
