Wall repair or wall under the window of our Victorian house
DanHowes
by DanHowes » Mon Mar 08, 2021 2:48 pm
We had some damage to the wall under the window of our Victorian house. I knocked out a mixture of brick, cement, rubble and cement to the current state in the picture.
My plan is to use shuttering and pour cement to rebuild this part of the wall. The area to be filled is 180cm long x 6cm deep and 25cm high.
Will this be ok to just cement or should I be also putting in some sort of bar or mesh to help support it? Also what sort of mix of sand cement would you suggest?
I will be leaving around 1cm to allow for plastering to finish along the front of the wall.
Any advice would be greatly appreciated, thanks in advance!
Shuttering
Shuttering
Wall
Wall
Re: Wall repair or wall under the window of our Victorian house
by stoneyboy » Mon Mar 08, 2021 10:24 pm
Hi danhowes
Use a ballast/cement mix around 4:1 and add stainless stitching bars for reinforcement.
DanHowes
by DanHowes » Tue Mar 09, 2021 10:14 am
Hi stoneyboy,
Thanks for your help. Do I need to embed the steel bars vertically in the stone base of the bit I’m filling or just lay them freely horizontally as I pour the concrete?
It is currently Sat Jan 04, 2025 10:07 pm
