pendant connection
bristol
pendant connection
by bristol » Sat Mar 27, 2021 1:46 pm
Afternoon all,
I removed the light pendant in our lounge for the ceiling to be plastered. When I went to reconnect, the light doesn't work. The light is served by 2 switches and the wiring from the ceiling in my photo is exactly as it was before the light was removed.
Grateful for advice please !
Re: pendant connection
by Mr White » Sat Mar 27, 2021 2:20 pm
The wiring may be the same but how about the connections?
I suspect you may have pushed the wire in too far and have screwed down on the insulation, not the conductor.
bristol
by bristol » Sun Mar 28, 2021 12:04 pm
Good morning Mr White,
Case solved !
Many thanks for getting back to me. As a layman I always seek to push the wire in as far as possible in the belief that it makes for the best connection.
Lesson learned !!
by Mr White » Sun Mar 28, 2021 3:56 pm
Happy to have helped. And thanks for letting us know. (Most people post once only to never be heard from again.)
It is currently Fri Nov 22, 2024 6:23 am
