What is the cause of this damp and green dusty mould?
Stuarty77
by Stuarty77 » Thu May 06, 2021 12:59 am
This rear wall is damp, with a vertical 'tide mark' of this green dusty mould. What is the cause?
There was also moisture on the wall itself
Re: What is the cause of this damp and green dusty mould?
by stoneyboy » Fri May 07, 2021 10:16 pm
Hi stuarty77
If you are referring to the dark strip next to the door frame then this may be as a result of replacement doors being fitted too far forward in the outer brickwork skin.
It is currently Sun Dec 22, 2024 10:14 am
