Protection of underground drainage pipe leading to a soakaway
Gates1664
by Gates1664 » Fri May 07, 2021 10:02 am
Hoping someone can help.
Building control have said I need to protect my drainage pipe that leads into a soakaway, even though it's just in that back lawned garden.
Any ideas what I use to protect it please? Whether I need a bed of concrete or whether stones will do?
Any advice would be appreciated?
Re: Protection of underground drainage pipe leading to a soakaway
by stoneyboy » Fri May 07, 2021 10:33 pm
Hi gates1664
That’s a new one on me unless you have used flexible drain pipe near the surface. Possibly the easiest solution would be to get some old guttering from a scrap yard and lay this on top of the drain pipe. Check this would be acceptable to BC.
It is currently Sat Jan 04, 2025 11:37 pm
