Advice on flooring level after removing ceramic tiles in bathroom
db3058
by db3058 » Tue Jun 15, 2021 10:17 am
Hi, lifted ceramic tiles from
A small bathroom, can see grey adhesive mostly in swirl shapes, and some floorboard when the grey had been lifted with ties.
Am I ok to lay underlay then vinyl click flooring ? or need to get rid of the grey stuff which is set like concrete and will be time consuming.
Thanks in advance
Dylan
Re: Advice on flooring level after removing ceramic tiles in bathroom
by stoneyboy » Wed Jun 16, 2021 9:48 pm
Hi db3058
If the floor is flat put underlay straight on it, if it’s uneven apply a layer of self levelling compound to give you a flat surface.
It is currently Sun Nov 24, 2024 3:21 pm
