How to repair damaged plasterboard after removing skirting boards
Chris_M
by Chris_M » Fri Aug 20, 2021 12:44 am
I'm looking for some advice on how to repair some plasterboard damage after removing skirting boards.
It's a new build property.
Have taken the boards off for when new flooring is going down soon then the boards will be going back on again but there's a few spots where the plasterboard has crumbled.
There's only a few patches but not sure how to repair this as new to this and never done this before.
Any advice would be much appreciated.
Thanks.
Re: How to repair damaged plasterboard after removing skirting boards
by stoneyboy » Fri Aug 20, 2021 10:35 pm
Hi chrism
If it has just crumbled and the paper backing is largely intact, skim over the area. If there are large holes, cut out a section and fit a new piece. Taper cut all edges so you can glue the new piece in with filler.
Chris_M
by Chris_M » Fri Aug 20, 2021 11:31 pm
Hi mate,
Yeah it is largely intact so I will try that.
Thanks for your reply.
Much appreciated.
Have a good weekend.
It is currently Thu Nov 21, 2024 10:09 pm
