MCB keeps tripping in new 10 way Schneider unit
Spence1412
by Spence1412 » Sun Sep 26, 2021 2:23 pm
Just installed a new 10 way Schneider unit.
All ok apart from downstairs ring.
The circuit tests ok.
A mains powered radio and one table lamp work but any more than that and mcb trips.
I have unplugged all appliances and plugged them back in one by one but they all cause tripping.
If there was a short then the radio and lamp wouldn't work would they.
Very confused.
Kevin
Re: MCB keeps tripping in new 10 way Schneider unit
by Mr White » Sun Sep 26, 2021 9:19 pm
You said
Spence1412 wrote: The circuit tests ok.
What is "OK" and who tested it? and what was it tested with?
Picture of what trips would help.
chriscba
by chriscba » Sun Oct 03, 2021 9:36 pm
Swap the rings over to see if the fault moves to a different circuit.
Then if it has, you have an over sensitive MCB.
So you can change it
by ericmark » Thu Oct 07, 2021 5:12 pm
I have a feeling it is not a MCB tripping but a RCBO or RCD?
I would guess wrong neutral, but as @Mr White says, who tested the circuits to show OK and how?
There should be an installation certificate showing test results, and either a compliance or completion certificate.
It is currently Mon Nov 25, 2024 2:16 am
