Water softener issue as it wont let water through
Stevejay720
by Stevejay720 » Fri Jan 21, 2022 7:01 pm
I have a water softener installed, but it won't let water through it,
When I press the manual regen it will drain down I can see it empty then it will fill up again,
But if I turn on the hot tap I get no water
I have a by pass system so can turn the feed to and from the softener off and the open the bypass and I get full water flow
Anyone able to point me in the right direction
Re: Water softener issue as it wont let water through
by Mr White » Wed Mar 02, 2022 2:33 pm
If you had of posted in the correct forum in the first place, someone may have been able to help, but posting in the members area is of little use as hardly anyone comes here.
It is currently Sun Dec 22, 2024 9:59 pm
