Extending loft hatch - What is this element in my roof, can I cut it?
mtharrison
by mtharrison » Thu Feb 03, 2022 1:09 pm
I'm extending my loft hatch between 2 joists. I don't need to go any wider as I have a hatch+ladder that fits, however I need to extend by 20cm in length.
As you can see in the image, there is a board running the length of the roof which is in the way of where my hatch would sit. What is the element, is it structural? It looks quite thin, not look images I've seen of roof binders before.
Is it safe to cut it/replace it by moving it a couple of cm?
Re: Extending loft hatch - What is this element in my roof, can I cut it?
by stoneyboy » Fri Feb 04, 2022 10:36 pm
Hi mtharrison,
The length of timber laid flat was fitted to keep the joists in place when the roof was being built. You can cut out a section to allow you to increase the loft hatch size.
It is currently Thu Jan 02, 2025 3:32 pm
