Hotpoint FDFEX 11011 dishwasher no water
Supersmithy
by Supersmithy » Sun Feb 06, 2022 5:26 pm
Hi there,
I have a Hotpoint FDFEX 11011 dishwasher. When I run a cycle it first runs the drain and pumps through a bit of water (I've had this into a bucket and it's clean, all the waste lines are clear). The waste pump seems to work fine and the filter is spotless. I can then feel water running down the inlet line but on a cycle there's little to no water making it through into the unit itself. Certainly not to the rotary arms and no sound of a pump or similar. If I pull the door open halfway through there is some water in the bottom but not much. I also get a bit of steam from the drying cycle.
Could it really be just the inlet valve? Even though a small amount of water is getting through? Does the unit rely just on water pressure or is there also a water inlet pump that could be kaput?
Any help much appreciated.
Thank you.
It is currently Sat Nov 23, 2024 3:11 pm
