Sticky residue from removing lino on top of wooden floor
garthynufc
by garthynufc » Wed Feb 16, 2022 9:55 pm
Hi, total novice here. Moved into a house last year where the previous owners put down lino on top of wood flooring (long story…) Hated the lino so pulled it up, but I can’t get rid of the stickiness from the wood flooring. I’ve tried scrubbing repeatedly with soap and water and also with nail polish remover, which have taken the majority off, but it’s still slightly like walking on a nightclub carpet. Can someone suggest something to use to finally get rid of this please? Is it a case of more elbow grease or would a specific product help? Cheers
Re: Sticky residue from removing lino on top of wooden floor
by stoneyboy » Thu Feb 17, 2022 10:15 pm
Hi garthynufc,
Chances are that it is spray carpet adhesive and you will only remove it by taking the surface off. Eg by sanding.
garthynufc
by garthynufc » Fri Feb 18, 2022 4:12 pm
Ah ok, thanks. That’s not good! Will give that a go on some areas and see what happens
It is currently Fri Jan 03, 2025 1:10 am
