Changing fused spur to single socket
GR1587
by GR1587 » Fri Apr 29, 2022 3:21 pm
I’ve recently changed a 13amp fused spur to a single socket.
It’s on the 32amp circuit breaker in the fuse box.
There is only one set of cables in the back of the socket (one each of L,N,E).
Im not sure where the wire comes from ie. another socket, junction box etc.
Will that matter or will I be better hardwiring to a fused spur?
Re: Changing fused spur to single socket
by stoneyboy » Sun May 01, 2022 10:53 pm
Hi gr1587,
Provided the socket passes testing and it has 2.5mm cables going to it and it is not for equipment outside you should be ok.
GR1587
by GR1587 » Wed May 04, 2022 3:02 pm
stoneyboy wrote:Hi gr1587,
Thanks,
I will get it tested by electrician when he comes to do a few other jobs. It is 2.5mm cable and for indoor use.
It is currently Wed Dec 04, 2024 8:53 am
