Gap around air brick between wall and floor
CoLo
by CoLo » Mon Jun 06, 2022 1:15 pm
Hi, please could you help.
After removing carpet / underlay and skirting, I found a gap between the floor and wall around an air brick.
House is victorian, so over 100 years old.
How can this be fixed before laying laminate and replacing skirting please? No owner the room gets so cold!
Many thanks,
CoLo
Re: Gap around air brick between wall and floor
by stoneyboy » Tue Jun 07, 2022 10:53 pm
Hi colo,
You could drop the air brick by one course, use a liner and fill above it with mortar. Alternatively form a duct using aluminium trays (it looks like you've done this already) and then apply expanding foam to bring up to floorboard level.
CoLo
by CoLo » Tue Jun 14, 2022 11:19 am
Thank you Stoneyboy, that's really helpful.
Will go with the alu ducting option (don't think it's there atm).
Thanks again, much appreciated,
CoLo
It is currently Sun Nov 24, 2024 10:03 am
