Water continually running in toilet cistern
SimplyEif
by SimplyEif » Fri Aug 12, 2022 4:30 pm
I noticed recently that water is continually running into the water cistern.
See attached images.
I tried adjusting the nut you can see but this didn't make a difference.
Any thoughts?
Close Up
Close Up
Overview
Overview
Re: Water continually running in toilet cistern
by stoneyboy » Sun Aug 14, 2022 10:14 pm
Hi simplyeif,
If you cistern is continually filling it must also be continually emptying. Have a look for the overflow and look in the pan for continuously running water.
Either way the most likely problem is that the washer in the fill valve has failed. Start by replacing the washer.
It is currently Thu Dec 12, 2024 5:51 pm
