Skirting/Architraves
harry1234
by harry1234 » Tue Oct 09, 2007 8:23 pm
Hello
I was wandering if someone could offer some advice regarding skirting board I brought earlier. The skirting is too thick for the acrchitraves and leaves an unsightly gap. Would it just be a case of purchasing new skirting but this time getting the right thickness, or can someone let me know of some way to sort this out.
Thanks in advance
gerryyy
by gerryyy » Thu Oct 11, 2007 8:52 pm
yeh, u could change ur skirting, but if you don't want to, u could do what i done. i bought decorative blocks to go on the top corners and where the skirting meets the archatrive. this may not suit you, but think about it
Oddbod
by Oddbod » Sat Oct 13, 2007 9:09 am
Hi, Gerryyys tip is a neat trick - nice one.
Much better than my alternative suggestion which would be to remove and replace (or pad out) the architrave. If you are redecorating anyway, it's not usually as hard to do that as it might look. It should come away easily. (Cut the paint where the architrave joins the rest of the door with a knife to minimise damage).
It is currently Wed Jan 01, 2025 11:38 am
