Fixing a leaking tap and removing middle section
Chewy71
by Chewy71 » Sat Sep 10, 2022 2:27 pm
Hi, I'm not at one with DIY but I'm trying to fix this leaking tap. I've removed the outer cap but not sure how to take out the middle bit so I can replace the washer. Any help would be appreciated. Cheers.
Re: Fixing a leaking tap and removing middle section
by stoneyboy » Tue Sep 13, 2022 9:38 pm
Hi chewy71,
The heads are fixed in place by a splined shaft. The chances are that the chrome bit is stuck on the shaft with lime scale, you will have to carefully lever the head upwards.
It is currently Thu Oct 31, 2024 9:45 pm
