Floor Polishing problem
vjratne1740
by vjratne1740 » Wed Oct 10, 2007 5:33 am
I use cardinal red polish (polish+wax brand) and floor poisher to polish my sitting room floor area. It gives a good shine. But this area is separate and used sparingly, as we have another small regular sitting area.
After 2 weeks or so, some white clouds appear in some places on the floor and needs re-polishing.
Why is this? How to overcome this problem?
vjratne1740
thedoctor
by thedoctor » Wed Oct 10, 2007 7:18 am
Assuming this is a wooden floor white blotches appearing as if under varnish and/or polish are usually a sign that some moisture has been varnished over. This may have been in the wood as you applied the finish. It has now been sealed in and is unlikely to evapourate out so you may need to remove the surface and allow to dry out. See our project on floor finishes.
vjratne1740
Floor polishing problem
by vjratne1740 » Wed Oct 10, 2007 7:24 am
Dear Doctor
This is a cemented floor which is 35 years old - polishing for 35 years or so, on monthly basis.
This problem cropped up recently about an year ago.
vj1740
pablo2
by pablo2 » Fri Oct 12, 2007 10:32 pm
It may be Blooming like the Doc said , I would note the affected areas then clean back and allow to dry then reseal . If it reoccurs in the same localized areas I would then look at the slab it self
It is currently Tue Dec 03, 2024 8:38 pm
