In process of resinsulating loft, found issue with upstairs lighting circuit
Ash556
by Ash556 » Wed Sep 28, 2022 1:38 pm
Been clearing out the loft to add an extra 170mm of insulation.
Found this wiring which I don't remotely like the look of.
Upstairs lighting circuit consists of 4 x LED downlights in bathroom, 3 in hallway, and 1 ceiling rose in each of the 3 bedrooms. An extractor fan for bathroom which is operated by light switch, and 2 plug sockets in loft (one was for shower pump which I have removed, other one for god knows what)
I will be removing both sockets as I may be wrong but having them both on lighting circuit seems mad.
Just looking for some advice to clean this up a bit and make it safe before I lay insulation on it.
All downlights in loft will be having loft lids installed over them (whoever did the work previously had ceramic plant pots over them)
Can I install a terminal box with a choc block inside and run the cabling into that?
I'd like to avoid replacing all the wiring if possible
Re: In process of resinsulating loft, found issue with upstairs lighting circuit
by Mr White » Wed Sep 28, 2022 8:16 pm
It is up to you what you actually do, but I would re-wire it for 2 reasons.
1) So I would not have to de-rate the cables (They are going to be covered in insulation, the amount of de-rating depends on the final load, thickness of insulation, clip them direct in open air, no problem.)
2) Remove the problem of shoddy work
It is currently Thu Dec 12, 2024 6:46 pm
