low voltage transformer
ma876
by ma876 » Wed Oct 10, 2007 8:03 pm
hi this might seem like a silly question but what does VA stand for on transformers? I`m guessing its the output rating, if so what would a 150va transformer discharge in the form of amps, watts?
kbrownie
by kbrownie » Thu Oct 11, 2007 8:14 am
HI ma876,
VA stands for the maxmium Volt Amp Rating This is the sum of Volts X Amps
so say that your mains voltage was 230V then the current would be 0.652A. (230x0.652=150VA)
Regards
KB
ma876
by ma876 » Thu Oct 11, 2007 10:55 pm
thanks kb, how would i work out how many 20w lamps i could run from a 150va transformer?
by sparx » Fri Oct 12, 2007 10:38 pm
seven!
150 divided by 20 = 7.5 & as you can't buy half a lamp it's 7 with a bit to spare!,
VA is as KB says Volts X amps = watts for a purely resistive load, if inductive such as motors transformers ect, then power factor reduces actual power available which is why gen. sets have 2 ratings watts & VA.
Makers always advertise in VA as numbers more impressive, a bit like Americam horse power, only pony power to our way of measuring!!!
regards SPARX
ma876
by ma876 » Sat Oct 13, 2007 4:53 pm
Thanx very much
It is currently Sat Nov 23, 2024 8:26 pm
