Condensation on circular single glazed windows
gene1888
by gene1888 » Tue Nov 01, 2022 2:13 pm
I have 2 circular windows which are only single glazed and they seem to generate large amounts of condensation. I recently stripped the wood surrounding them as the room is getting renovated. My questions are 1. Is there anyway to stop this condensation without having to install double glazing? as I dont really have the funds for that. 2. Is there something I could treat the wood with to prevent the water affecting it over time? 3. Should I be using a special sealant around the window as there is going to be water present alot of the time?
Many thanks.
Re: Condensation on circular single glazed windows
by stoneyboy » Wed Nov 02, 2022 11:07 pm
Hi gene1888,
Regular painting is probably the best way to extend the life of the frame. You could try sticking a circular piece of plastic onto the frame - a continuous ring of sealant is essential.
gene1888
by gene1888 » Sun Nov 06, 2022 8:06 am
Hi thanks for the reply, I recently painted it but the photos attached show the stains.
by stoneyboy » Sun Nov 06, 2022 9:35 pm
Hi gene188,
Did you use oil based paint or an emulsion paint?
It is currently Mon Jan 20, 2025 5:14 am
