Cold spot on upstairs landing?
Pepsiandcoke
by Pepsiandcoke » Tue Nov 08, 2022 5:31 pm
Does anyone know if this is a cold spot upstairs as in photo . Wall is not damp but cold spot is spreading . If cold spot how would you fix ?
What is it?
What is it?
Re: Cold spot on upstairs landing?
by stoneyboy » Fri Nov 11, 2022 9:59 pm
Hi pepsiandcoke,
Looks like a leak in a pipe could even be in the loft with water coming down inside the wall.
Pepsiandcoke
by Pepsiandcoke » Sun Nov 13, 2022 4:22 pm
stoneyboy wrote:Hi pepsiandcoke,
what sort of pipe could it be ?? Who would be able to check and fix ? Easy fix ? How would they get into wall
Pepsiandcoke
by Pepsiandcoke » Sun Nov 13, 2022 4:34 pm
What sort of pipe could it be ? What person would would be able to check ? Easy fix ? How would they get to pipe in wall ?
by stoneyboy » Mon Nov 14, 2022 10:21 pm
Hi pepsiandcoke,
If it is a pipe leaking and you have water tank(s) in your loft I would suspect the mains pipe in the first instance. Start looking for leaks in the loft.
You would need to start with a plumber to see if they can find the cause.
If the wall is a stud wall cutting a hole in it and making good should be relatively straightforward.
If the wall is a masonry wall start by using a metal detector (or a person with one) to see if pipes are buried in the wall.
It is currently Wed Jul 03, 2024 9:20 am
