Torbeck Vertical Valve Problem
Henryvl
by Henryvl » Fri Dec 23, 2022 4:46 pm
The toilet started filling slowly - about 5 minutes to fill.
I cleaned it all but it looked ok really.
I put it back together and it worked first time.
However the second flush was slow, and I noticed some of the water was jetting
where the float arm joins the valve.
It only stops if you close the float arm.
Any advice would be most appreciated.
Re: Torbeck Vertical Valve Problem
by stoneyboy » Sat Dec 24, 2022 10:06 pm
Hi henryvl,
Save yourself a lot of frustration and fit a new valve. Depending on the valve you have fitted you may only need to replace the valve head.
Henryvl
by Henryvl » Sun Dec 25, 2022 12:40 am
Thank you.
It is currently Sun Dec 22, 2024 4:22 pm
