Old paint found after removing wallpaper
S.Willson1
by S.Willson1 » Wed Dec 28, 2022 10:03 am
Hi all, I’ve been removing wallpaper and it has revealed old paint that is flaking in areas. We are planning on painting the walls.
My question is do I attempt to remove the old paint? and if so what should I use?
Re: Old paint found after removing wallpaper
by stoneyboy » Thu Dec 29, 2022 9:50 pm
Hi s.wilson1
Suggest you scrape off loose paint using a thin blade scraper e.g. a filler knife, sand down the wall and paint. If you expose bare plaster the first coat should be a mist coat.
Wear a mask when sanding so you do not inhale the dust.
It is currently Thu Nov 21, 2024 10:15 pm
