Leaking Ideal Standard Cartridge Tap
NeilGlos
by NeilGlos » Sat May 27, 2023 5:22 pm
Hello
I have an Ideal Standard cartridge mixer washbasin tap, it started leaking from around the neck, just below the lever. I replaced the cartridge with a like for like replacement, as this was the advised solution, but the leaking persists.
Any advise on what else I could try?
Thanks in advance.
Re: Leaking Ideal Standard Cartridge Tap
by stoneyboy » Mon May 29, 2023 10:15 pm
Hi neilglos,
assuming you lubricated the seals on the new cartridge and cleaned the mating surfaces there is the possibility of a fissure in the tap around where the cartridge screws in.
If you find this is the problem a new tap is the only solution.
NeilGlos
by NeilGlos » Mon May 29, 2023 10:24 pm
Thank you for the reply. The cartridge doesn’t screw in itself, rather it’s inserted and held in place by three screws. This is the type https://www.mytoiletspares.co.uk/ideal- ... pares.html
Could there still be a fissure, how could I tell?
Being a DIY “newbie”, what sort of lubricant should I have used?
Thanks again
by stoneyboy » Tue May 30, 2023 10:11 pm
Hi neilglos,
The seats at the back of the housing should be cleaned with a fine grade emery (or something similar), cleaned and then a light smear of silicone grease applied.
Have a look around the area where the rubber seals locate - after you have cleaned them - and see if there are any tracks (very fine cracks which will have stained with minerals in your water).
It is currently Fri Nov 15, 2024 3:10 am
