My wardrobe doors do not hang straight.
Baby Tim
by Baby Tim » Sun Jun 18, 2023 4:23 pm
The previous owner who was carpenter left wall to walls wardrobes in my bedroom. Instead of getting rid of them, I decided to up-cycle them with new doors. There are four wardrobes that have been joined together with 8 doors that have been replaced. The carcasses are not handmade they are probably MFI however they are very sturdy. I have fitted 4 doors using concealed hinges with no problem and they are fine. However, the last four doors are mis-aligned, uneven and do not close properly. I have tried adjusting the concealed hinges but nothing seems to work. I was supplied with Hafele hinges and have used the Hafele hinge hole repair kit when needed. I have also used 4 mm packers to help the doors meet in the middle. I cannot think of what to try next . Any suggestions?
Re: My wardrobe doors do not hang straight.
by stoneyboy » Tue Jun 20, 2023 9:36 pm
Hi baby tim,
Most likely problem is that the carcasses are not vertical, not level and not lined up. Sort this out and your doors should fit.
It is currently Sat Dec 28, 2024 9:37 am
