Domestic water supply to taps
PANDY80
by PANDY80 » Sun Jul 30, 2023 11:51 am
A friend with plumbing experience helped in installing new parts to an existing system. New stoage tank, new CH header tank, new hoy water cylinder and some rads.
Now the hot water to taps is poor and hot water doesn't last.
Any help would be gratefully received.
Re: Domestic water supply to taps
by stoneyboy » Wed Aug 02, 2023 9:46 pm
Hi pandy80,
Assuming the installation has been done correctly:
It depends what you mean by “hot water to taps is poor”. If you are saying the flow is poor then you should check for airlocks.
Hot water not lasting may be due to the position or setting of the hot cylinder thermostat.
PANDY80
by PANDY80 » Thu Aug 03, 2023 8:52 am
Thank you for this. Flow to taps is o.k. Water just won't heat to previous temperatures with the cylinder thermostat reset to above pre-set and boiler setting upped to a mark on dial of 3 whereas at this time of year it is 1 (no CH on).
by stoneyboy » Thu Aug 03, 2023 9:45 pm
Hi pandy80,
Assuming you have an indirect HWC is the tank stat fitted below the return pipe level? Have you checked the tank stat turns on and off? What temp is the tank stat set at? When the system is on are both primary flow and return pipes hot going into the HWC. If you have a motorised valve is this working correctly?
PANDY80
by PANDY80 » Fri Aug 04, 2023 8:42 am
Going to get this all checked out once we return from a holiday. Thanks again.
It is currently Mon Dec 02, 2024 3:54 pm
