isolation of hidden sockets
Marteeze
by Marteeze » Sun Jul 30, 2023 3:50 pm
we have had installed a double socket at the back of our wall mounted TV and because it is so flush we are unable to turn the switch to the off position meaning the tv is always at standby , the electrical guy took a spur off a nearby double socket but i was thinking that he could have changed out the supplying socket with a isolation switch something similar to a cooker socket this i am presuming the allowance of turning the new socket off tv no longer at standby and still have the availably of use of the socket for hoover ect
would this be a doable request and if so is there anything similar to a cooker socket on the market
Re: isolation of hidden sockets
by Mr White » Sun Jul 30, 2023 11:53 pm
Yes. You can get an isolation switch rated for 32A (With neon too)
I should point out that the cost of said switch and having it installed means you would recoup your money in about 10+ years as a TV on standby uses so little.
It is currently Thu Jan 09, 2025 3:57 pm
